Hello, Im a Guitar Pickup Maker, trying to automate my winding machines- SOS HELP ..
How do you do that. or How do you not do code?
You can just download the default grbl package to your arduino and it works out of the box. You then send gcode commands from your PC to the arduino to turn the stepper the required amount. Installation instructions are here: https://github.com/grbl/grbl/wiki/Compiling-Grbl
Next. When winding 1000 turns there is no problem with +/- 1. My high power transformers have numbers line 10 and there can not be any error. My counters count tenths of a turn. That way some slippage in the shaft encoder is not as much of a problem. (some times I need to back up a little and fix a bump in the winding and then go on) A home made shaft encoder struggles with that.
There's no shaft encoder for feedback, and there'll be no slippage if you have a sufficiently-powered stepper motor. You can then tell it to turn the shaft with resolution less than a degree.
AU$13 Stepper motor: https://www.ebay.com.au/itm/NEMA-17...nter-extruder-36oz-in-26Ncm-0-4A/123006287929
AU$1.30 Stepper motor driver: https://www.ebay.com.au/itm/1PCS-A4...r-Polulu-StepStick-RAMPS-RepRap-/221921771119
AU$4.74 Arduino uno: **broken link removed**
Here's https://www.redlion.net/product/paxl-dual-counter-rate-meter-dual-relay-output a product that should do what you want. I didn't scour the companie's website for other suitable products.
It just might be inconvienient to program.
One of these https://www.alliedelec.com/omron-automation-h7cxawd1ndc1224ac24/70178543 models may work too and be easier to program. Looks like increment/decrement for each digit. I'm not saying that this is the model you would want.
I realize you might need more help.
These are probably found under counters/timers or totalizers.
I used a mechanical turns-counting dial from reddington for a work project long ago.
My first coil winder. Has 1/4 horse power and foot pedal speed control. You can't see the size but I have made 1000 watt transformers. About 40 years ago we added a speed reduction so I could pull heavy wire.
This is a small version I made. I need to have much less power. It runs from a bench supply. By setting the current limit small it will stall out the motor before it breaks the wire.
You can not see the 1/4 horse gear motor behind + counter with stop switch etc. It was built to wind degaussing coils for TVs. It also makes metal detector coils.
It makes coils as small as 4 inches to as large as many feet. I have many jigs. The one shown is about 2.5 feet across. I added red lines to show the shape of the coil.
guitar pickup forms are a rather odd shape for a winding machine, as they are about 2.5 inches by 0.3-0.75 inch and about 0.75 inch tall. the wire pull force varies a lot because of the aspect ratio of the coil.
OP not been seen for over a week. Think this one is a dead thread.
Unfortunately it's definitely looking that way....
Go to Gibson user site and ask. Several winders there. You can use a digital (optical) shaft counter but they aren't cheap. You really need variable speed motors so you can slow down before stop (sewing machine motor?) and GOOD tensioner. Google the Gibson vintage wider machines for soapbars.. IIRC the cheap commercials use a veeder type counter with a rubber wheel that runs on the winder shaft.
