Hearing aid diagrams??
rx5
hello all,
newbie here.... just wondering.. anyone got links/schematics to a simple hearing aid?? w/o using exotic IC.. but just using ordinary components??:D
and one more thing, could thier operation rival with commercial hearing aids??:rolleyes:
thanks..
Audio aids
Very, very complex signal processing, research, and design and goes into commercial audio aids, so a homemade one will absolutely not be able to compete.
A homemade hearing aid would probably just be an audio amplifier. It might probably be:
Microphone->Audio Amplifier Circuit->Speaker
The audio amplifier using the most "regular components" would require an "operation amplifier" IC (Op Amp for short). Read up on amplifiers circuits that use op-amps. You also need to look at a few microphone input and speaker output circuits (which isn't hard, it is almost directly connecting them directly to whatever you need)
It also unlikely to be small enough to work as a hearing aid (seeing as how an IC can already the size of a hearing aid). Hearing aids used specialized chips and such to get them to be small.
I should add that hearing aids are customized to the user. Since the needs are different and different persons register different frequencies. So you shouldn't borrow hearing aid from somebody else.
It's pretty neat what goes into hearing aids. Anyone read that recent article in "IEEE Spectrum" about the hearing aid that preprocesses and filters the d ata bio-mimetric analog processing before digitization?
rx5 said:
Ah ic..... too bad.. i found 2 schematics on the web.... all using transistors.. and push-pull config to drive the phones....
Yes making a cheap hearing aid is easy, any nube knows how to do that, but making a good one isn't easy at all.
