Hi Experts,
Looking for some guidance, My amp (BlackStar HT Club 40 MKII) began having very loud humming, my actions as they occurred :
Note i have a chain of pedals as well- not cheap pedals name brand i run through the loop. I have not began to eliminate these yet but will after this post.
Please note also i am a hobbyist, yes i understand tube amp voltage and how to bleed the voltage so i can poke around and stay alive thanks for concerns, i am not a expert in electronics but have been hobbling with circuits for a little over a year now. By no means expert--- if you respond please dumb it down a bit for my sake and so i do not aggravate you with unintelligent questions lol.
Thanks for the consideration to help out. I have some video if that helps but cannot seem to be able to post here.
- Install new 12Ax7 (EC83) pre-amp tubes - JJ tubes
- Started up the amp, played with same hum no change
- After i flipped the amp over and began taking readings with MM, i hit a connection with positive lead and the Output fuse 500Ma250v blew.
- I replaced the fuse, same hum issue
- I then decided to check the Power tubes, i removed the first Ruby EL34 Power Tube in line and swapped it with a Winged C el34, the mains fuse blew.
- I stopped- ordered matched set of JJ EL34 power tubes, replaced the fuse
- Cranked the amp up- first thing i notice is the hum was very low now on hi gain stages, feeling great i biased tubes
- This model has two green LED and Pots you turn when green glows bright they are biased correctly per design) I did not use MM for this btw
- After playing for about 6-10 minutes i experienced a volume loss then immediate return of volume-
- Swapped cables, guitars, cabs (16ohm Cabs btw)
- Problem is still there.
