Got my p16Pro
Squintz
I got my programmer and its fully assembled. And i went to the store and baught the parts to connect it to my variable power supply and i got some solder type protoboards. Now all i need is for micro to deliver my sample pics i ordered last wednesday.
About how long did it take for you guys to receiver your free samples?
Also i notice that the pic programer uses a DC plug but it says it accepts ac and dc. What is the polarity of the DC? is it Positive or negative center?
Exo
Active Member
took about 2 weeks for me...
but this is belgium... once it reaches the postal offices here things get really slow :lol:
Squintz
OK i got the PIC16pro and i got my PIC16f84a i built a circuit shown here:
Now i want to take the code from that site and program my PIC
What software do i need? Please give free ones and links are good!
Kane2oo2
you need a program which turns that assembler code into a hex format which can be programmed into the chip.
the most well known is MPLAB which can be found at the microchip webiste and is free
:D
Kane
Camping
Open your files in a project. Then at a node. Then tell wich PIC you have and then you BUILD ALL. And then you see in your work space a HEX.
Cya
isaacj
It does not matter. The plug connects to the rectifier bridge, so whichever plug configuration you use the programmer will still work.
while waiting from a responce from you guys i ound PicALLw software
the picallw software was written by the guy that designed the programmer. His software is not free, if you want to use a PIC other than the F84 you'll have to register your software. A free programmer that works with the p16pro is
Squintz
ok... Got the IC-Prog and installed it. And i have the following code.
 org 0x00                     ;This is where we come on power up and reset
 ;*******************SETUP CONSTANTS*******************
INTCON           EQU 0x0B       ;Interrupt Control Register
PORTB            EQU 0x06       ;Port B register address
PORTA            EQU 0x05       ;Port A register address
TRISA              EQU 0x85       ;TrisA register address
TRISB              EQU 0x86       ;TrisB register address
STATUS          EQU 0X03      ;Status register address
          COUNT          EQU 0x0c         ;This will be our counting variable
 TEMP              EQU 0x0d      ;Temporary store for w register
  goto    main                                     ;Jump over the interrupt address
;***************INTERRUPT ROUTINE***************
  org                  0x04                ;This is where PC points on an interrupt
  movwf            TEMP              ;Store the value of w temporarily
 incf                  COUNT,1       ;Increment COUNT by 1, and put the result
                                                 ;back into COUNT
 movlw 0x0A                           ;Move the value 10 into w
 subwf              COUNT,0       ;Subtract w from COUNT, and put the
                                                ;result in w
 btfss                STATUS,0       ;Check the Carry flag. It will be set if
                                                ;COUNT is equal to, or is greater than w,
                                                ;and will be set as a result of the subwf
                                                ;instruction
 goto                carry_on           ;If COUNT is <10, then we can carry on
 goto                clear                 ;If COUNT is >9, then we need to clear it
carry_on
 bcf                  INTCON,0x01 ;We need to clear this flag to enable
                                                 ;more interrupts
 movfw            TEMP              ;Restore w to the value before the interrupt
  retfie                                      ;Come out of the interrupt routine
clear
 clrf                  COUNT          ;Set COUNT back to 0
 bcf                  INTCON,1      ;We need to clear this flag to enable
                                                ;more interrupts
;*******************Main Program*********************
 main
 ;*******************Set Up The Interrupt Registers****
 bsf                   INTCON,7      ;GIE – Global interrupt enable (1=enable)
 bsf                   INTCON,4      ;INTE - RB0 Interrupt Enable (1=enable)
 bcf                  INTCON,1      ;INTF - Clear FLag Bit Just In Case
 ;*******************Set Up The Ports******************
  bsf                STATUS,5     ;Switch to Bank 1
 movlw 0x01
 movwf TRISB                      ;Set RB0 as input
 movlw 0x10
 movwf TRISA                      ;Set R 0 to RA3 on PortA as output
  bcf                  STATUS,5  ;Come back to Bank 0
 ;*******************Now Send The Value Of COUNT To Port A
 loop
movf                 COUNT,0       ;Move the contents of Count into W
movwf              PORTA           ;Now move it to Port A
goto                 loop                 ;Keep on doing this
 end                                           ;End Of Program
now do i put that code into an text file and save it as "FILE.asm" and then goto open file? When i do that it ask me if i want to swap bits.
Can someone please explain what i do once im in the program. I have already setup the prog as the link above said to. and i'v picked that im going to be programming a pic16f84a. Whats the next few steps? When i first chose my PIC that i was going to be programming the window filled up with all kinds of HEX? What is all that Hex code for. Do i delete this hex?
Exo
Active Member
First go to MPLAB IDE
Choose 'Project' - 'New' to create a new project
give it a name and a destination folder
Then choose 'project' - 'add files to project' and add your file.asm to the project
then choose 'project' - 'build all' to compile your file (turn it into machine code HEX file)
The now produced hex file (if you have no errors) is the one you need to open with ICPROG
Squintz
;back into COUNT
;result in w
;instruction
carry_on
;more interrupts
clear
;more interrupts
main
movlw 0x01
movlw 0x10
loop
end ;End Of Program
Deleting intermediary files... done.
Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mpasmwin.exe" /q /p16F84A "LED.asm" /l"LED.lst" /e"LED.err"
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 11 : Found opcode in column 1. (goto)
Warning[205] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 14 : Found directive in column 1. (org)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 15 : Found opcode in column 1. (movwf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 16 : Found opcode in column 1. (incf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 18 : Found opcode in column 1. (movlw)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 19 : Found opcode in column 1. (subwf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 21 : Found opcode in column 1. (btfss)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 25 : Found opcode in column 1. (goto)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 26 : Found opcode in column 1. (goto)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 28 : Found opcode in column 1. (bcf)
Warning[204] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 30 : Found pseudo-op in column 1. (movfw)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 31 : Found opcode in column 1. (retfie)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 34 : Found opcode in column 1. (clrf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 35 : Found opcode in column 1. (bcf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 37 : Found opcode in column 1. (retfie)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 41 : Found opcode in column 1. (bsf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 42 : Found opcode in column 1. (bsf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 43 : Found opcode in column 1. (bcf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 45 : Found opcode in column 1. (bsf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 46 : Found opcode in column 1. (movlw)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 47 : Found opcode in column 1. (movwf)
Message[302] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 47 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 48 : Found opcode in column 1. (movlw)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 49 : Found opcode in column 1. (movwf)
Message[302] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 49 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 50 : Found opcode in column 1. (bcf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 53 : Found opcode in column 1. (movf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 54 : Found opcode in column 1. (movwf)
Warning[203] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 55 : Found opcode in column 1. (goto)
Warning[205] C:\DOCUMENTS AND SETTINGS\OWNER\MY DOCUMENTS\PICS\LED.ASM 56 : Found directive in column 1. (end)
Loaded C:\Documents and Settings\Owner\My Documents\PICs\LED.COD
BUILD SUCCEEDED: Fri Oct 24 18:53:04 2003
Why all the errors.... I got this code right from a web site and tryed to convert it into hex with MPLab and no luck!
Exo
Active Member
They're warnings, not errors (the build succeeded, see the last line)
Microchips assembler persists that you nicely format your file...
Put labels at the beginning of a line, and code after some tabs, and so on
like this
    ORG 0x00
    goto main
Main
    org 0x04
    movwf TEMP
    incf COUNT,1
    End
It is meant to make your code more readable and easyer to understand
... You got to admit, the code you posted looks like quite a mess without format
Squintz
BUILD SUCCEEDED: Fri Oct 24 20:23:46 2003
Now all i get is this? What does it mean?
Exo
Active Member
Bank selection messages, you'll get them all the time, even when code is correct..
ignore them or add ERRORLEVEL -302 to the top of your code
Exo
Active Member
i can't see any clear wdt commands in the code so no, disable the watchdog. Otherwise the pic will reset in the middle of the program because the watchdog timer overflows
Squintz
Im using picall now because the IC Pic does not work on my computer. The pic call pops up a message when i try and burn the chip.
Program error:
Program adress=000 buffer=2811 device=3fff
when i first load the HEX file i get the message:
Warning:
Configuration word is not
included with the hex file !!!
For detail look at the PICALLW.HLP section FAQ!!!
What is the configuration code? I looked at the Help file but did not understand it! Thank you all for helping me through all this
damonwill
Same problem
I have the same problem. I can program a chip once, and then when I erase it and re-program it gives me the first error message. Any thoughts?
:evil:
Nigel Goodwin
Super Moderator
Most Helpful Member
The configuration word sets the various configuration options for the processor - oscillator type, WDT, code protection and various others depending on the particular PIC. It's essential to set these correctly, and it's advisable to do so in the source code so it's included in the HEX file. Not doing this results in the warning message you got, which essentially is prompting you to set them in PicAll before programming the chip.
