Generating square waves of 0-5V voltage levels
km
Hi there, I have a problem with my circuit. I suppose to get a square wave output with voltage levels 0-5V at point A, but when I test my circuit with the circuit maker simulation, it gives me a different answer. What should I need to do in order to get the desire output? :roll:
With "C4" in the output of the circuit, you have created an RC differentiator. With this in the circuit, you will see only pulses at test point "A", a positive pulse when Q2 turns on and negative one when Q2 turns off. JB
The input is 1MHz. 47nF and 450k (1Meg || 820k) is a 750 Hz highpass. This would only be a differentiator for square waves in the range below a few hundred Hz.
Goodpickles, you'll never get 0-5v out of that circuit, because the power supply is only 5v. You can get close with the following changes:
R5=390
R4=1k
C3=47pF
R7=1Meg
With these values, my sim shows a 0.46v to 4.68v square wave (well, sorta square).
THanks Ron for all the values you gave!! It works :wink:
After the output, if I want to get a clean sqare wave, what should i do? Can I connect a "Quad 2 input NAND with schmitt trigger" ? :idea:
you could try a schmitt trigger made from an op-amp and some resistors, then you would be able to adjust the hysteresis to get a particular duty cycle (if you need it)
if you just need ANY sort of rectangular wave out of it, then you could use a comparator, or that NAND you mentioned (with inputs tied together... making it basically a schmitt trigger inverter)
You don't need to jump through so many hoops. The circuit below will give you a 0-5v square wave.
Be sure to connect +5V and GND to pins 14 and 7, respectively. Connect a 100nF cap from +5V to GND, as close to the chip as you can get it, and with short leads.
Connect all unused inputs to GND.
Thanks Ron. :wink:
What you mean by that? and Whats that triangle connect to D2?
The circuit that you have gave me will it able to convert different amplitude and frequency of a sine wave to a 0-5V square wave with the same frequency?
km said:
Thanks Ron. :wink:
It's an HT decoupling capacitor, in any high speed logic circuits you should fit one across each chip. You wouldn't usually bother drawing them on a circuit diagram, just as you don't usually show the HT connections to the chip.
The 'triangle' is a 'ground' symbol, the 0V connection of the circuit.
Yes, it's a 'schmitt trigger', it converts the incoming signal to a square wave - with a sinewave input it will be the same frequency, with much more complicated waveshapes this won't always be so.
The triangle is a symbol for GND, or circuit common.
This will convert large amplitude sine waves (4v p-p to 20v p-p) into square waves at the same frequency. You never specified variable amplitude or frequency. Over what input amplitude and frequency range do you need it to work?
