Function Read and Write EEPROM
Winch
Can someone provide me with some additional information about the function Read and Write.
I have some problems with the processing of the code in the program.
Why do these simple code below not work properly?
'DEVICE PIC16F628A
Define CONFIG = 0x3f50
Define CLOCK_FREQUENCY = 4
AllDigital  'alle ports digital
'Poortnamen
Symbol led = PORTA.1
Symbol s1 = PORTB.0
'76543210
PORTA = %00000000
TRISA = %11111011
TRISB = %11111111
OPTION_REG.7 = 0
Read 0, led
main:
While s1 = 0
Wend
WaitMs 10
Toggle led
Write 0, led
While s1 = 1
Wend
WaitMs 10
Goto main
End
Ok never mind.... You can't compile it..
led is defined as a bit.... Read and write require bytes.. Use a port buffer to access the bits..
'Poortnamen
Symbol s1 = PORTB.0
'76543210
PORTA = %00000000
TRISA = %11111011
TRISB = %11111111
Dim portbuf As Byte
OPTION_REG.7 = 0
Read 0, portbuf
led = portbuf.1
main:
While s1 = 0
Wend
WaitMs 10
Toggle led
portbuf.1 = led
Write 0, portbuf
While s1 = 1
Wend
WaitMs 10
Goto main
End
Oke, I did try this.
It looks to work. But I am not sure?
The intention was to make the LED high (make the output high) write to the "0" address of the EEprom en read it again out with the result the LED high output. And visa versa.
Now it looks like to work just the other way the LED is high if you take the power supply of and back again then the LED is Low. And visa versa.
What I don't understand in this code is you write "portbuf.1" what is that ".1" exactly doing?
I use this solution earlier but without that ".1" now I am wondering what does that?
Please explain this.
Accessing bits within a byte,, The dot operator can achieve this...
portbuf.1 accesses bit 1 within the byte..
