Function not returning a value
johnl69
Im relatively new to C programming and have been following books and online tutorials but i cant find an answer any where.
Ive written a program to adjust the brightness of an LED, when you hold switch RA4 the program goes to a function to adjust the PWM value "green_val" eveerything works as it should in the function but when I return to the main program the "green_val" registry returns to 0 rather then what it was set to in the function.
C:
#include <stdio.h>
#include <stdlib.h>
#include "pic16f874a_Config.h"
#include "lcd.h"
#include "pic16f874a.h"
#include "delays.h"
#define duty 1
void main(void)
         * configure CCP module as 4000 Hz PWM output
PIR1 =255;
T2CON  =0b00000101 ;
CCP1CON  =0b00001100 ;      //Configure PWM Mode, Set DB bits to 10
CCPR1L  =0b00000000 ;       // reset to zero
Init_Pic();
lcd_init();
RC0=1;
    unsigned int green_val;
    for(;;)
            CCPR1L = green_val;
            lcd_goto(0);
            lcd_puts("green_val1");
            if(RA4 == 0)
                lcd_clear();
                Set_Green(green_val);
unsigned int Set_Green(unsigned int green_val)
    lcd_goto(0);
    lcd_puts("Green");
    while(RA4 == 0)
        {       // digital adjustment of duty cycle
                if(RA5 == 0)//Brightness up
                    if(green_val == 255)
                    else
                        green_val++;
                        lcd_goto(0x40);
                        lcd_putch(green_val);
                        __delay_ms(50);
                if(RE0 == 0)//Brightness down
                    if(green_val == 0)
                    else
                        green_val--;
                        lcd_goto(0x40);
                        __delay_ms(50);
        CCPR1L = green_val;
    lcd_clear();
    return green_val;
The function returns the variable...
it should be..
C:
green_val = Set_Green();
If you pass a parameter ie.. Set_Green(green_val); You need to point to it.
C:
Set_Green(&green_val);
And the function would need no return..
C:
void Set_Green( unsigned int* green_val)
   // adjusting code...
Thanks for that not sure if I understood correctly because now im getting "error (984) type redeclared" and "error: (1098) conflicting declarations for variable "Set_Green".
C:
#include <stdio.h>
#include <stdlib.h>
#include "lcd.h"
#include "delays.h"
#define duty 1
void main(void)
PIR1 =255;
T2CON  =0b00000101 ;
Init_Pic();
lcd_init();
RC0=1;
    for(;;)
            CCPR1L = green_val;
            lcd_goto(0);
            if(RA4 == 0)
                lcd_clear();
                Set_Green(&green_val);;
    lcd_goto(0);
    lcd_puts("Green");
    while(RA4 == 0)
                    else
                        green_val++;
                        lcd_goto(0x40);
                        __delay_ms(50);
                    if(green_val == 0)
                    else
                        green_val--;
                        lcd_goto(0x40);
                        __delay_ms(50);
                CCPR1L = green_val;
    lcd_clear();
Where is the function definition???
It was:-
unsigned int Set_Green(unsigned int green_val);
It needs to be:-
void Set_Green(unsigned int* green_val);
C:
#include <stdio.h>
#include <stdlib.h>
#include "lcd.h"
#include "delays.h"
#define duty 1
void main(void)
    PIR1 =255;
    T2CON  =0b00000101 ;
    Init_Pic();
    lcd_init();
    RC0=1;
    for(;;)
            CCPR1L = green_val;
            lcd_goto(0);
            if(RA4 == 0)
                lcd_clear();
    lcd_goto(0);
    lcd_puts("Green");
    while(RA4 == 0)
                    else
                        green_val++;
                        lcd_goto(0x40);
                        __delay_ms(50);
                    if(green_val == 0)
                    else
                        green_val--;
                        lcd_goto(0x40);
                        __delay_ms(50);
                CCPR1L = green_val;
    lcd_clear();
I did change the function definition to what you had put and got the errors.
Ive just copied and pasted your code to a new file and get the same errors? I cant see it declared in any of the header files
pic16f84a_config is just pin definitions
C:
#include <stdio.h>
#include <stdlib.h>
void Init_Pic(void)
    TRISA  = 0xff;
    TRISB  = 0x00;
    TRISC  = 0x00;
    TRISD  = 0x00;
    TRISE  = 0x03;
    PORTB  = 0x00;
    PORTC  = 0x00;
    PORTD  = 0x00;
Okay Simple.... Just put one at the begining..
C:
#include <stdio.h>
#include <stdlib.h>
#include "lcd.h"
#include "delays.h"
#define duty 1
void Set_Green( unsigned int* green_val);
void main(void)
    PIR1 =255;
    T2CON  =0b00000101 ;
    Init_Pic();
    lcd_init();
    RC0=1;
    for(;;)
            CCPR1L = green_val;
            lcd_goto(0);
            if(RA4 == 0)
                lcd_clear();
    lcd_goto(0);
    lcd_puts("Green");
    while(RA4 == 0)
                    else
                        green_val++;
                        lcd_goto(0x40);
                        __delay_ms(50);
                    if(green_val == 0)
                    else
                        green_val--;
                        lcd_goto(0x40);
                        __delay_ms(50);
                CCPR1L = green_val;
    lcd_clear();
If this works I have no Idea how your first code compiled correctly...
Yep that's true.... I forgot to mention that we are now remote... All operations to "green_val" have to be pointers..
C:
    lcd_goto(0);
    lcd_puts("Green");
    while(RA4 == 0)
                    if(*green_val == 255)
                    else
                        *green_val++;
                        lcd_goto(0x40);
                        lcd_putch(*green_val);
                        __delay_ms(50);
                    if(*green_val == 0)
                    else
                        *green_val--;
                        lcd_goto(0x40);
                        __delay_ms(50);
                CCPR1L = *green_val;
    lcd_clear();
now the programs not working properly the led goes from on to off with 1 button press rather then the smooth progression I had before and it still reverts to zero once I release the button.
It is really a bad idea to use pointers on PIC16 devices, especially that old as yours, unless there's a compelling reason to do so. Just make green_val a global variable instead of passing it to the function as a argument. It's the most efficient and the easiest solution.
I would swear that that port in that micro is open collector if set as output. Most, if not all the old ones, had that trap armed for the unwary. Not C conversant myself. In a next life maybe...
YES that worked thank you for everyones input.
Im using this pic because I have it and dont want to fork out for a pickit 3 to use the newer chips.
Why?
Passing a pointer is as easy as having a global variable... I try to make newbies learn how to use them... I use structures and pointers to structures even on the little pic12's
I had this return value zero , only fix that worked was this suggestion from NG .
( Note My C sucks ! )
Pointers are one of the fundamental parts of C.. They allow parameter lists to be kept to a minimum.. I also agree that using global variable everywhere is favoured by lone programmers..
sprintf( buff, "arg list"); is a classic example.
LCDputs(buff); is another..
I will write the above program using a pointer to show why it works and why it didn't..
Okay!!! I've had this before but have forgotten!!!
*green_val++; // <-- Increments the pointer first..
(*green_val)++; // <-- Increments the location..
I was stung by this a couple of years back.... If the operator is out side the brackets it works fine...
*green_val++ is the same as *(green_val++).... Not what I wanted..
Sorry!!! I should have tested the code first!!
