From assembly to c in MPLAB IDE v8.30
PIC2PIC
Hi
I always used assembler for programming my PIC-s. Now I think it might be nice to go to C. It probably will not be a problem to learn C but I don't know how to or is it at all possible to make a .hex file with MPLAB IDE v8.30.
You simply need to buy a compatible C compiler, and installl it - MPLAB works with various ones. As long as you use 18F series PIC's, you can download a free C18 compiler from MicroChip.
You can use hi-tech C to in lite mode it should be installed mircochip kind of pushes it on you when you install mplab
If I was you and you use a lot of 16f chips I woutd give Jalv2 a try it a good compiler
this is good for the 18F chips to
http://www.casadeyork.com/jalv2/
This is good if you want to work with just 18f chips Its swordfish basic it's like visual basic
http://www.sfcompiler.co.uk/swordfish/
But is C is what you want Hi-tech or boostC
http://www.sourceboost.com/Products/BoostC/Overview.html
http://www.htsoft.com/
If 18F chips
Hi Nigel and Burt,
There is also mikroC and mikrobasic also mikropascal, code limit on the non registered versions, works for the 16F and the 18F but has separate IDE than MPLab. But the built in functions are helpful if you want to start programming immediately.
Compilers - mikroElektronika
Hi all .Thank you for your help.
@ Wond3rboy
Is it possible to make a .hex file from program "microC PRO for PIC " . I install that program but I think it can't make a .hex file. I use PIC 16f***
MiKroC is some what a pain but here is a some window shot showing how there 10 pic the pictures should tell it all.
  • mickroC.zip
    mickroC.zip
mikroc is good easy to learn but if you don't save your project the right way it hard for a noob to find them
Hi 3V0 and Burt,
They have put up examples/source code on their site. Its for the 16f877.
But like 3V0 said try to stay of the libraries, people get stuck more often than getting their problems solved. Besides, its better for a good learning experience that you do every thing manually first.
