freeview receivers
kibosho
was wondering if freeview receivers can be converted from rgb to sxga siganal for pc monitors, am aware there are adaptor to convert them but i needed know if additional IC or transistor be used?
thanks
I though you could buy freeview TV tuners for PCs, wouldn't is be easier to use one of them?
re:freeview
hi
I already have freeview receiver and also subcribed to sky, was looking for cheapeast option and now i have found SCART-VGA Sync product code A38BF, which looks quite expensive compare to parts if buy from them (ie sockets and cable ) now am just in need of wiring diagram , anyone one would be able to provide one
cheers !
As in the thousands of similar posts in forums and newsgroups every year! - you can't do it, TV and VGA are totally incompatible - different line and frame speeds. In order to do it you need considerable electronics, digitising the singal in real time, storing it in memory, and reading it out at a different rate.
