Hi, I've been trough lots of fm transmitter discussion but i'm looking more for a cookbook approach to solving my problem. I'm looking for input on solutions and correction when my assumptions are wrong
Goal: I want to extend the range of a centronix fm transmitter for car radios built around the BH1415F chip. I am aware of the legal aspects of such undertaking.
The broadcast should be well received to regular car type quality receivers or portable mp3 receivers within 100 meters in an open space. The sound quality will be dvd. And i want to do this cheaply, less than 50$. I have a 'scope and electronics experience (logic, audio, opto, ) but no RF experience.
The way i see it, there is either some antenna configuration that makes this range possible, or i build a RF amplifier which takes the ouput from the BH1417F chip). Still i want to minimize RF energy going outside of the receivers area.
Question1 : How do i calculate how much RF energy needs to be broadcast at this range (100m)? Is there a cookbook approach to this? From this i can determine how much amplifying in need.
BH1415F info:
Specs (click here to download) say the RF power (Transmission output level) is typically 100dBuV. If i convert this to milliwatts (**broken link removed**) i gives me 20.00046. So this is the RF power going out of pin 11. Is my logic correct? And how sensitive are cheap car radio, and how does it relate?
Question 2: Can a passive or inexpensive active antenna amplify the BH1415F signal to the level required?
Question 3: If an (cheap) antennae cannot do it then i found various transmitters schematics but they are probably either too powerful or involved.
I am open to suggestions as to which design to use. I have thought of using part of Audioguru's fm transmitter (mod4) for this job, or this Ipod 1w xmitter which seems a bit overkill.
Question 4:
If i use Audioguru's circuit i would need to couple BH1415F pin 11 (apparently expecting 50ohms impedance) to Q3. Here i am totally at a loss on how to calculate and implement the impedance matching. I'm looking for pointers or a cookbook approach / reference on soving this.. i'm getting back into electronics after 25 years and those particular memories have been recycled long ago
Thanks for you patience and help.
Gordito
BH1415F info:
Question 4:
Gordito
