Floating value on LCD
neelam29
Hi friends,
I'm doing programming in Hitech C, my uC is PIC16F877A & displaying on 16x2 LCD I'm trying to display a integer value on above line & floating value on lower line of lcd using the following commands, the integer value is comming but the floating value isn't comming instead it's showing ' f ' on LCD
lcd_goto(0x80);
x_int=314;
sprintf (buf, "%d", x_int);
lcd_puts(buf);
lcd_goto(0xC0);
y_float=11.22;
sprintf (buf, "%f", y_float);
lcd_puts(buf);
a similar thing i had done with keil C51 & At89c52 it was working properly.
Can you please guide me.....
With best regards,
Neelam
Are you sure that the compiler and the library function can even dispaly a floating point number?
Try sending the integer and the float to the same location but separated by time. This will rule out address overflowing.
Does lcd_goto() use the actual command for the address or the hex address itself? For instance, 0x80 is the command code to position at address 0x00. Your lcd_goto() seems to operating more like lcd_command(). lcd_goto(0x00) for first line and lcd_goto(0x40) for second line makes more sense.
Are you compiling with the -LF option? I believe that the standard library, 96LIBC.LIB, contains versions of sprintf and printf that do not support floating point.
You need to make the compiler use the 96LIBF.LIB instead.
