finding pic sillicon revision numbers
ghostman11
can anyone explain how you read from the pic what it's revision number etc is? i have a couple of pics that have errata on some revisions but not others and i wanted to check the chips i have
ok thanks for that i will have a go at it later, even under a microscope i cant see anything that looks like a revision number:confused::confused:
Use the Pickit2 CMD exe it will tell you all the info you want to no.
ok how do i use this :D:D:D i double click to run and a screen flash's up then is gone in a fraction of a second
When I first connect to a target device with a PICkit 2 running under mplab 8.36, I get the following report:
Found PICkit 2 - Operating System Version 2.32.0
Target power not detected - Powering from PICkit 2 ( 4.75V)
PIC12HV615 found (Rev 0x0)
PICkit 2 Ready
This is before I click 'program'.
I would assume that it would do the same for any other PIC device.
Hi Jason,
extract "PK2DeviceFile.dat" & "pk2cmd.exe" & stick in a folder close to root (saves navigating many paths).
Connect PICkit2 to a device.
Open a command prompt & navigate to the chosen folder, then type "pk2cmd -p -i" then hit return.
Mine was a 16F887 and I got:
Auto-Detect: Found part PIC16F887
Device ID = 2080
Revision = 0002
Device Name = PIC16F887
Operation Succeeded
Regards.
EDIT:
Simply typing "pk2cmd" without switches & hitting return gives the command line help options.
Watching Silk?
A programme on the forsaken gogglebox?
Are you under duress from the better half? ;)
There's 'scopes un-attended and constantly refreshing forlornly out there you know! :D
