Faulty heat air gun (dc motor) - problem to locate fault due to Intermittent fault [unrepairable]
Grossel
Hi. I have this simple hot air gun that have a fault where the blower motor suddenly runs slower mid operation for no obvious reason.
Disclaimer: When I describe the loss in power and try to put a number on it (i.e. half power) - this is only due to audible sound, vibrations etc. that can be felt. No measurements involved and the actual loss of power might hold a different value.
Key features of heat air gun
  • Simple DC motor + diode bridge. Most probably connected in series to some heat element within the heater.
  • Heater design: Unknown. Don't know if any connection issue within the heater may be the cause.
  • Power switch, 3 states - OFF, power.sw.pos. 1 (less heat and slower fan) and power.sw.pos. 2 (2kW heating and air blower goes full speed)
  • Fully insulated - there is no ground connection (230VAC)
This is the observed faults so far
  • While normal operation, about 5 minutes of use (power sw pos. 2 ~2kW): Speed of motor drop to about half power. The temperature seems to remain the same, but no measurement so can't be sure. Moving the power sw. to pos 1 - the motor still runs much slower than expected. After device being cooled down, starting the device in power.sw.pos. 2, it runs normal again.
  • Test run (see picture) - DC voltage being measured over the dc motor using an analog voltmeter (all test performed when power.sw.pos. 2): First run the motor DC voltage are stable at ~18V. However this was measured in semi faulty state, because after power off and on again caused the motor speed to run slightly faster (normal speed) and the DC voltage over the motor was now 20V.
    • This means that (at least in this semi faulty state) - the voltage over the motor drop compared to when it operate in non-faulty state.
  • Test run with clamp amperemeter (6A range). Motor seems to run just fine, cannot tell if it runs at full speed or slightly slower. Motor draws about 1.4A (slightly below according to the needle). However, I was not able to re-produce the fault so I cannot tell if the amperage also goes down on fault or not (it ran for over an hour at 2kW, I started the unit over again ten times during that time - but still failed to reproduce the fail state)
  • When the device goes in fault state - the speed of the blower motor remains stable. The fault state does NOT cause the DC blower motor to run erratically.
Key points (I've learnt this from AI, not being an AI myself - but who can really tell nowdays)
  • The faulty state are hard to reproduce, but seems to be more likely to occur under normal use (when device being held by hand) as opposed when it lays down on the ground (being tested).
  • Fault state can behave different from time to time, some times the motor speed is just slightly reduced, but other times the fan speed goes at half speed.
  • Speed remains stable in faulty state.
  • Voltage over motor drop when in fault state. Don't know if current drops or stay the same (and therefore unable to tell for sure if the fault is in the motor itself).
Ok - all of the above is facts, as observed. I've thinking that I have 2 suspected fault causes, but still doesn't have good measurement to pin point the actual cause. Hopefully some have some experience with heaters that can shed some light on this.
Motor failure (theory one)
This is just a simple DC motor with permanent magnets. If this is the failure point, the measurements can be explained: Winding on the rotator inside the motor being shorted. This will cause the dc motor to run less effectively. The voltage drop may therefore be caused by fewer windings.
Faulty connection within the heater element (theory two)
This may also cause a voltage drop to the motor.
What do you guys deduce from this information? What is more likely to be the point of failure, the motor or the heater (some failure within) ?
If it's two power levels, it likely has two electrically parallel elements, one in series with the motor and with the second switched in directly across the supply for 2KW.
The old Bosch one I have has what looks like two sets of elements wound one inside the other.
Could one of the elements be "drooping" after a while and shorting across to the other element? Depending on the winding configuration, that could divert some current from the motor?
It could explain why it does not do the same when on its side.
Ok, maybe I try to open the heater tomorrow. Anyway, this is how the internal wiring is done inside - but without details of the heater, it ain't very useful.
If the motor is powered via a tapping on the heater element wire, the tapping connection may deteriorate when the element gets hot, hence reducing power to the motor.
Yes, that sounds likely as both settings are affected.
In practice this means the heat gun in practice are non-repairable as opening the heater require cutting/breaking off the plates being kind of popped in place.
Where I now work (for the last seven plus years) we have a Bosch heatgun, which we use every day for heat shrinking - it was there before me as well, and the owner (and old friend of mine) said he got through numerous cheap heatguns before buying the Bosch, the cheap ones barely lasted a year if you were lucky.
Per the split heater power tap idea, that connection gets hot, and reduces voltage to the motor, but that loose connection would fail, more likely, the motor gets hot, and an internal winding starts shorting out, reducing the field strength. I'm thinking where the silicon steel stack, expands, and cuts into the varnish of a winding. When it cools down, that shorting path opens again.
I suggest doing resistance measurments betwee the 4 wires going into the heater assembly. From that you may be able to work out the way the supply for the motor is obtained from a section of the heater elements. Also measuring the voltage between the motor terminals when it is working normally and when it slows down may help us to understand what is happening. (Post the resistance measurments and voltage readings. Do something to distinguish between the 2 white wires in the results.
Les.
Measurement already done when running normal, if you read what I wrote the main issue is actually the lack of ability to provoke the fault at will. If the fault occur, and I then open it up for test - the heat gun operate normally and thus cannot be tested.
See the picture attached to the first post, I had it running for more than an hour like that without being able to reproduce the failure state.
Btw there is only one difference I can think of between the test (when measuring) and during normal work (only relevant assuming the motor is the faulty part): When the plastic housing are mounted and under normal operation, the intake air have to pass through/around the dc motor and thus cause cooling. But when tested and the plastic housing are taken off, the intake air doesn't cool down the motor in the same degree.
If this factors in for the likelihood of the heat gun entering fail state, I don't know.
[edit]
Attachment - updated drawing that includes resistance measurements (cold state, room temperature).
This is how I think the heating element part is arranged.
The motor derives it power from the voltage developed across the 3.2 ohm part.
I suggest monitoring the current taken by the heat gun and note if the current drops when the motor slows down. If the current does not change the fault will most likely be the motor. (Or the diode bridge on the back of the motor.)
If the current drops the fault is probably in the heating element part or high resistance contacts on the switch.
Les.
Yes, I agree.
But running this heat gun for hours just for it to maybe enter faulty state, make for a very costly bill from the power company.
