Failure to receive the correct Preamble
bravehamid
HI
I'm using a USRP to receive a signal on the 900 MHz frequency band, but the signal received after demodulation has no preamble. Does anyone know what the cause is?
transmitter information:
Baud rate=10K
modulation = BFSK
deviation = 100K
channel spacing = 350K
You may think you've given us all the information required but I've no idea what USRP means. Also, no preamble, no data too?
USRP is a costly SDR radio
There are some cheaper in the $1000 to $2000 range.
In collage, this is what girls said to me before they walked off "Failure to receive the correct Preamble".
there's
Baud rate=10K
modulation = BFSK
deviation = 100K
ok, that's what you need to demodulate the signal, but once that is done, what is the protocol the transmitter is using? this is where sync/preamble/header and data format are defined...
