EUSART not working properly
mikesmixes
I am trying to configure the EUSART in a PIC18F2620....
See attached code.
The problem is that I recieve the correct characters but also the incorrect characters...
like happy faces and W's and > when all I should be receiving is T's.
Even when writing a String, there were incorrect characters withing the String.
Thanks.
Mike
//Library includes
#include <p18f2620.h>
#include <usart.h>
//My includes
#include "Main.h"
#pragma config OSC = HS //Oscilator = High Speed
#pragma config WDT = OFF //Watch Dog timer = ON
#pragma config PWRT = OFF //Power up timer OFF
#pragma config LVP = OFF //Low Voltage Programming = OFF
void InitializeBoard()
	TRISCbits.TRISC1 = 0; //LED to show button pressed
void ConfigureUSART()
	// configure USART Fosc=25Mhz, BR=19200, 8bits,
	OpenUSART( USART_TX_INT_OFF &
	USART_RX_INT_OFF &
	USART_ASYNCH_MODE &
	USART_EIGHT_BIT &
	USART_CONT_RX &
	USART_BRGH_HIGH,
	80 );
	//Enhanced USART Configuration
	baudUSART (BAUD_IDLE_CLK_LOW &
	BAUD_8_BIT_RATE &
	BAUD_WAKEUP_ON &
	BAUD_AUTO_OFF);
void main(void)
	int busy = 0; //USART Busy
	int buttonState = 0; //Last button state to detect falling edge
	int send = 0; //Send request
	InitializeBoard();
	ConfigureUSART();
	while(1)
		PORTCbits.RC1 = !PORTBbits.RB5; //Set state of LED
		if( PORTBbits.RB5 < buttonState ) //Detect falling edge
			send = 1;
		busy = BusyUSART();
		if(!BusyUSART() && send ) //Send required and USART available
//			putrsUSART( "Test String, button pressed\n" );
			WriteUSART('T'); //Send just one char
			send = 0; //reset send request
		buttonState = PORTBbits.RB5; //Set last state of button
Have you double checked the baud rate being used at both ends? Do they match? Is this on a breadboard? Have you checked for loose connections?
Yes, I have double checked the baud rate both ends. I am using a pcb based around Jorge's EIP-10 Ethernet board.
Does the configuration seem correct? I have checked it, but maybe I'm missing something.
Thanks.
Apart from the comment that the WDT should be on but set to off, everything else looks ok.
80 is the correct setting for the baud rate generator, one thing I am not to familiar with is the EUSART baud settings, however, I am aware of this:
Inconsistencies in baudUSART()
It discusses some inconsitencies with the baudUSART function, may be worth a look.
Wilksey
