ESR Capacitor tester
It certainly looks like that project is well worth the time, but instead of an analog display you might find a digital one more satisfactory.
Austin
True, but haven't been able to find many on the web. There is one from Elektor magazine that I found, but uses a double sided board and a lot more work.
If you don't need the precision of a digital readout, an analog readout is generally easier to read and observe trends. Since you usually aren't interested in high accuracy in measuring ESR, I would stay with the analog readout.
Yes you could still go with an analog display if that would make things easier for you; but to truly get the most accurate reading possible a digital display is the way to go.
Austin
Accuracy is sometimes overrated.
Just need to find aa source for a cheap 50ua meter. Not cheap if buying from the major retailers like newark or digikey. I suppose I could connect the output to my dvm
