Error while building.
Nick'
include "P16F628A.INC"
bsf STATUS,5
movlw 00h
movwf TRISA
bcf STATUS,5
movlw b'00000101'
movwf PORTA
Debug build of project `C:\Documents and Settings\user\My Documents\MPLAB\LED.mcp' started.
Language tool versions: MPASMWIN.exe v5.33, mplink.exe v4.33
Preprocessor symbol `__DEBUG' is defined.
Mon Sep 28 13:26:00 2009
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "LedAsmProject.asm" /l"LedAsmProject.lst" /e"LedAsmProject.err" /o"LedAsmProject.o" /d__DEBUG=1
Warning[205] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 1 : Found directive in column 1. (include)
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 2 : Found opcode in column 1. (bsf)
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 2 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 3 : Found opcode in column 1. (movlw)
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 3 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 4 : Found opcode in column 1. (movwf)
Message[302] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 4 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 4 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 5 : Found opcode in column 1. (bcf)
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 5 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 6 : Found opcode in column 1. (movlw)
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 6 : Executable code and data must be defined in an appropriate section
Warning[203] C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 7 : Found opcode in column 1. (movwf)
Error[152]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 7 : Executable code and data must be defined in an appropriate section
Error[129]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLAB\LEDASMPROJECT.ASM 8 : Expected (END)
Halting build on first failure as requested.
Debug build of project `C:\Documents and Settings\user\My Documents\MPLAB\LED.mcp' failed.
Mon Sep 28 13:26:01 2009
BUILD FAILED
I have created a simple project where 2 LEDs will be on. I have added the header file, "P16F628A.INC" into the header files folder in the LED.mcw. What is the problem here? It stated there that i did not define those.
You have selected relocatable or added a linker script. I suggest you start with absolute code. Start a new project and choose absolute when asked, then add the following,
		#include "p16f628A.inc"
		__config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _BODEN_ON & _MCLRE_ON & _WDT_OFF & _CP_OFF
		org	0x0000
		bsf	STATUS,5
		movlw	00h
		movwf	TRISA
		bcf	STATUS,5
		movlw	b'00000101'
		movwf	PORTA
stop		goto	stop
		end
it is so complicated.What are those for?
Cant i do something like import the modules eg. #include "p16f628A.inc" and continue with my codes as usual? As when the header file is imported, using the declared/defined keywords should be fine.
Those are the fuses. You need to set them before burning the pic. In this case the pic will use the internal oscillator, and you need to connect master clear to vcc.
What I usually do is to define my settings once and then copy and paste it to each new project I do.
		org	0x0000
                      movlw	0x07              ; I think these should also be added
	           movwf	CMCON
		bsf	STATUS,5
		movlw	00h
		movwf	TRISA
		bcf	STATUS,5
		movlw	b'00000101'
		movwf	PORTA
stop		goto	stop
		end
My first Flashing LED never worked until I figured you need to add those 2 lines
