Error programming 16F628
This may not help.
You do know that there is a big difference between programming 16F628 and the 16F628A, do you? Just checking to make sure you are using the non-A PIC.
If all else failed, try using a legacy PC running Win98.
Why would his programmer be able to program the non-A and not the A version? Isn't that dependant on the programming software used?
Greg, try removing all installed printer drivers, or any driver bound to the LPT port used for the programmer on your PC.
BTW, the non-A version hasn't been available from Microchip for a while now.
Of course, some suppliers still offer it, but the A version is generally cheaper. At least that's the case at Digikey.
So you should not assume anyone's using the obsolete part. It makes no sense to get the non-A version nowadays.
ok - tried the led program. nothing happens! so i presume its not being programmed properly.
I'll uninstall my printer drivers and let you know what happens.
also checked - its def the non-a version I'm using. its a pic16f628-04/p
i've deleted all my printer drivers and tried setting my parallel port to normal, it was set to epp - no difference. I've attached a pic of my board. The wires are connected to a ic socket.
if it helps any - this is the hex of the blinking leds program:
:020000040000FA
:020000000428D2
:08000800FF30A100FF30A2004F
:1000100007309F00211033200530162023142F2095
:100020000530162023102F200C281528A4002408A2
:10003000A5006430A6000A301D28A700FF30A800E4
:100040002608AA002508A9007730280703182528C4
:10005000A90B2428AA0B2228A70B20280800302847
:0E0060002308850008003428210865000800E8
:02400E00623F0F
:00000001FF
below is the hex after I program the pic and read it back - shouldn't it be the same :x
:020000000428D2
:10000400A100FF30A20007309F00211033200530EB
:10001400162023142F200530162023102F200C28FF
:100024001528A4002408A5006430A6000A301D2861
:10003400A700FF30A8002608AA002508A9007730E9
:10004400280703182528A90B2428AA0B2228A70B64
:1000540020280800302823088500080034282108B7
:04006400650008002B
:02400E00623D11
:00000001FF
You said you were using a shielded printer cable, yet all i see is a bunch of unshielded wires wich are curled together. It won't work like that...
how long are these wires ? i've had p16pro40's fail because of 15cm unshielded wires between progger and pic...
yip - its grounded to the dc in. and powered by the circuit.
picture attached.
Hmmm, I think you got it Exo! That would explain the weird behaviour.
Those wires connecting the socket to the circuit look a bit long... They might pickup radio stations and write a mix of object code and "Stairway to heaven". I think I recognize a guitar riff encoded in that second hex file :p:lol::p
the shielded cable is between the computer and the programmer.
between the programmer and the pic I have the single cables. no longer than 10cm
Yes, try replacing them with shielded cables and untangle them, curling them up increases wire capacitance greatly...
Hi gregmcc,
Your programmer is fine. See the comparsion of the two files(I make them into two files from your previous posting) you have posted.
What you have read back from the PIC is actually what you have programmed, except with one error which happened while programming and caused offset in address.
Why the error happened I can't tell. Except that the "FF30" at address 0008 just disappeared into thin air and the rest of the code placed into address starting from 0004.
There appears to be a one-bit error difference in the last word but as it is the config word and that the difference location is bit9 which is not implemented in the config word so it is not an error.
i've now tried to untwist all the wires - made no difference.
i think the time has come for me to give up on this programmer and try another type. i tried the jdm programmer before this one and that didnt work either :-(
Your programmer is OK.
Your programmer is functional.
Your programmer is good.
Just try another programming software. :twisted:
