Elevator feedback system
Korama
hello,
sorry for my english. I’m trying to model an "elevator system" graphically using « Functionnal block diagram »
The layout of this system is
My block diagram
1. Please is my model correct ?
2. if i’m in level 2 and want to go to level 3 .is the input of command card in this case will be
Level desired : 0011
Position sensor : 0010
Is that mean i will have 4 signals for level desired and 4 signals for position sensor ?
For braking I assumed that the control will be binary 0 if the engine is running and 1 if the engine stops. However in the description of the system (figure attached) they propose different brake control !!!
hello,
My block diagram
I am not sure about the type of block diagram you are referring to, you have position sensing, motor forward & reverse command, brake sensing & braking functions.
your block diagram should compare current Level & decide the direction
keep on driving to that direction until set level is reached.
then stop motor and check for position for brake to be reached
apply brake.
Regarding digital part of the control
since you have only 4 positions (levels) its ok to have 2 digit binary coding (00,01,10,11)
the braking here is based on sensor too, when both the level and brake positions are similar - apply brake.
