electronic meter use in water
Electronic2050
hi to all
i am working on "electronic distance meter" project
this meter using in boat and when we turn it on it
measure the distance that moved in water same as kilometer counter
in cars for example when we move with boat for 100m the sensor
send digital singnal proportionate with this distance
now i need a sensor that do this,anybody know any sensor
or any low cost and cheap metode for measuring distance
thanks mr rb
i don't using of GPS because i want use of microcontroller to
other applications.
Use a GPS module with a serial output and a microcontroller with a UART. Then you can just read/interpret the GPS data and do other tasks with your micro as well...
I used a tiny motor with a propeller, which gives you speed, and then you'd have to integrate the output to get distance.
hi and thanks
can you give more information about this method such as data sheet catalog
or other data...
dear friend thanks for your idea but i think to this method i have problem to month motor because it most in to the water and in undulatory water may
destroy the motor.
There's 2 problems with that;
1. Boats are very often used against the flow of the water (or with it) so if there are any currents your readings can be WAY out.
2. The nature of the flow over the boat hull changes a lot depending on boat speed (planing etc) and angle of the boat (cargo etc) and cavitation effects. So you need a deep water sensor for the speed which is a real pain since it still doesn't solve problem 1.
