srynznfyra
Hi
I'm building (well, designing at this stage) a simple fan controller to switch one or more fans between either a 12V or 7V supply (using +12V, +5V and ground to achieve the different voltages). This of course makes use of the fact that if you connect something to 12V and 5V, it will receive an effective (12 - 5)V, as the 5V 'pushes back'.
Each fan will have its own toggle switch between 12V, 7V and off, but there will also be a 'turbo' SPST toggle switch to turn all fans up to 12V. The fans are part of my PC's cooling system, and the point of the turbo switch is so that I can quickly turn all fans to the max if the PC is overheating, or if I'm leaving it for a while doing some heavy work (heh, noise doesn't matter while I'm not in the room). I'd also connect a thermistor in parallel with the turbo switch, so if it does overheat it will automatically turn the fans up.
The difficulty I'm having is that I'm trying to accomplish all this using a transistor for each fan; to be precise, an NPN transistor. Here's the schematic:
Basically the principle I'm using here, and it might be totally wrong, is that I'm connecting the turbo switch to the base of each transistor (in parallel obviously). Each fan's negative is connected to its respective transistor's collector in parallel with a SPDT switch, however before the switch is a resistor (we'll come to that). The SPDT switches between 5V and 0V for the fan's ground, for an effective voltage of 7V and 12V (respectively) going through the fan. This means that assuming the transistor is OFF, you can manually switch the fan between 12 and 7V (ie. loud/quiet).
Now is where it gets tricky: the transistor's emitter is connected straight to ground. Does this mean that when the transistor is ON, all the electricity going through the fan will go through the transistor (and to 0V for an effective 12V/loud)? Or will there be current leakage through the resistor and (assuming it is switched to 7V) to the +5V supply?
I guess I'm sort of combining a 1-input AND gate with a 1-input NAND/NOT gate using a single NPN, so I wouldn't be surprised if this wreaks havoc
Thanks alot, and I hope you understood my long-winded explanation, although the diagram should help (lol).
Cheers
Cheers
