Hello,
I was wondering how are these motors protected in case of simultaneous up and down branching error. Can someone help?
Thanks in advance
rolling shutter motors has 3 leadsA motor in a bridge circuit has only two leads.
The direction of the current through the leads determines the motor rotation direction.
Then you would need some sort of interlock logic to prevent both directions from being energized at once.rolling shutter motors has 3 leads
Thanks. I would simply like to know what protection is built into the shutter motors. I think that there should be such a protection simply because there can be wiring mistakes even by a professional so there ought to be tolerance for such faults. And that even prolonged erroneous wiring should not be destructive.Then you would need some sort of interlock logic to prevent both directions from being energized at once.
Why are you concerned about this?
That's not normally done.Thanks. I would simply like to know what protection is built into the shutter motors. I think that there should be such a protection simply because there can be wiring mistakes even by a professional so there ought to be tolerance for such faults. And that even prolonged erroneous wiring should not be destructive.
Because I have not seen a 3 lead motor it is hard to know what is happening. I need to know more about how the motor is used. Where are these three wires going?rolling shutter motors has 3 leads
