E1 transceiver interface with MC 89s52
thakarbhargav
I am doing a project on G.703 (64Kbps) to E1 (2Mbps) conversion. The 64Kbps (as per G.711 A-law standard) signal is readily available on G.703 port & my plan is to map this 64Kbps data into TS1 slot of E1 frame and extract the same at receiving end & vice-versa. While doing so I have found a IC which can help me in doing my job:
1. Maxim: DS2155.
So, I'll need a little help in understanding the interface part of this IC's with intel or motorola processor (as it says in the datasheet). i.e., how do i interface this IC with processor & which processsor or controller should I use or do i have to use a micro-controller (AT89S52 or any other), dsp or fpga???
(Note: I dont want any software configurable part, simply map the 64kb data in to 2mb & extract it at the receiving end).
Thanks & Regards.
