Resource icon
Dual-mode microphone pre-amplifier 2011-12-17
alec_t
Most Helpful Member
alec_t submitted a new article:
Dual-Mode Microphone Pre-Amplifier - This is a microphone pre-amp which I designed for use with a SoundBlaster(TM) AWE 64 Value sound c
This is a microphone pre-amp which I designed for use with a SoundBlaster(TM) AWE 64 Value sound card; but it should be suitable for any compatible card or PC audio input which provides a 5 Volt supply (via a 2k2, or thereabouts, built-in current-limiting resistor) at the ring contact of a stereo jack plug inserted into the "Mic In" socket of the card/PC. (N.b. it has only been tested with the AWE 64 card.)
The circuit has the following features :-
(1) It will automatically...
Read more about this article...
On the schematic, the slider of VR1 is not connected so it is a fixed resistor, not a potentiometer.
Audioguru
You're quite right AG. Wrist duly slapped. It's only used as a pre-set resistor, not a true pot. I'll correct the schematic pro tem, but I'm working on a revised version of the amp and will post that in due course (don't hold your breath!)
Alec
Audioguru
Now connected!
