Resource icon
Battery - Accurate, Low-Voltage Cutoff To Prevent Complete Battery Discharge 2018-05-29
crutschow
Most Helpful Member
crutschow submitted a new article:
Battery Low Voltage Cutoff To Prevent Complete Battery Discharge - Circuit disconnects battery from operating accessories at a specific voltage to avoid dead battery.
Accessory usage when a vehicle's engine is stopped can excessively drain the battery and prevent an engine restart, thus it is desirable to have a circuit that can monitor the battery voltage and disconnect the accessories when a specific discharge level is reached.
Here is a circuit using a TL431 voltage reference IC as a comparator to turn off an accessory relay at the desired voltage.
In this application, the TL431 is not used as a voltage regulator, but acts as a comparator with a...
Read more about this article...
