Vizier87
Active Member
Hi guys,
I recently acquired this sample from TI.
So according to the datasheet, regarding Vref and Vset:
However, I have another idea, since using resistors will be a bit tedious with the board I'm fabricating being small and whatnot, I'd like to achieve a 3.3V regulation by connecting 3.3V to Vref and GND to Vset. That will also set it to 3.3V, isn't it?
Thanks for any input here.
Vizier87.
Reference Output
The DRV8832 includes a reference voltage output that can be used to set the motor voltage. Typically for a constant-speed application, VSET is driven from VREF through a resistor divider to provide a voltage equal to 1/4 the desired motor drive voltage.
For example, if VREF is connected directly to VSET, the voltage will be regulated at 5.14 V. If the desired motor voltage is 3 V, VREF should be 0.75 V. This can be obtained with a voltage divider using 53 kΩ from VREF to VSET, and 75 kΩ from VSET to GND.
Vizier87.
