double inverting using 741?
By double inverting do you mean double invert the polarity?
If you double invert any signal you will get back what you started with.
e.g invert +5V to get -5V
invert -5V to get +5V
sorry if i have missunderstood your question but it seemed a strange one to ask thats all
andy
The LM741 is a single OP Amp, so I don't know what he's getting at?
With a single inverter you can only invert once. If you wanted to, you could configure it as a buffer and then say the signal is inverted 2*n times.
j.
yes u r right
i need to convert 10voltage into 20voltage ....... :roll: is this -Non-inverting Operational Amplifiers worki for me and who
circuit will help i guess
are you after 10V POWER to 20V POWER?? If that is the case you need a DC:DC converter.
If you are after 10V SIGNAL to 20V SIGNAL use an OPAMP but arrange it as a non-inverting amplifier instead of an inverting amplifier
The gain of an inverting amp is
-Rf/Ri
The gain for a non-inverting is
1+ Rf/Ri
So by using the feedback and input res as both 10k you will get a gain of two.
Search google for "non-inverting amplifier circuits"
I highly doubt the humble 741 can achieve the output voltage swings you require, not to mention that you would need a reasonably high voltage dual supply.
If you have a lower power supply, use a DC-DC convertor. Else use a voltage regulator, or a series of zeners for low-current applications.
