DIY (cheap) CR2032 battery holder
TaDa
I made a very cheap and rudimentary dolls house light using an led, resistor, a switch and a cr2032 battery.
I soldered all the bits I could but for the battery connection I just duck-taped some exposed wire to the battery (!!)
This worked, for a while but the duck-tape is a 'sub optimal' solution - in that it doesn't work :)
This whole project is meant to be _really_ cheap - so, gathered experts, is there a better (but still cheap) way to connect up the CR2032?
Don't know your location but Radio Shack sells a CR2032 battery holder for about a buck. Something like this. Also most parts houses carry variations. The advantage to brick and mortar store is you walk in and out with the thing.
Home brew? Maybe modify a clothes pin or binder clip? However, if you have access for a buck I would just buy one.
Ron
I'm UK based so I guess bricks'n'mortar would mean Maplins.
But, no, I want this to be dirt cheap _and_ really neat - I'm probably being overly hopeful (as usual) but if I don't ask....
FYI I'm currently trying to work out how I can press a coke bottle screw top neck and lid to my purpose :)
