disabling interrupt in code vision avr
avisekdg
i tried to use interrupt INT0 of atmega16..
i wnt to disable interrupt once the program enters the INTERRUPT SUBROUTINE and enable the interrupt once the ISR gets over. but for the interruot to start for thr first time #asm("sei") needs to be given in the main()..
i want to enavle interrut once and then disable it in the ISR..
i have given my code below.
plz help..
interrupt [EXT_INT0] void ext_int0_isr(void)
#asm("cli");
delay_ms(4.752);
for(i=0;i<11;i++)
PORTC=PIND&&0x04;
PORTA=0x00;
delay_us(864);
PORTA=0x01;
delay_us(864);
PORTA=0x00;
delay_us(864);
PORTA=0x02;
delay_us(864);
PORTA=0x00;
void main(void)
PORTA=0x00;
DDRA=0xFF;
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x00;
DDRD=0x00;
#asm("sei");
while (1)
// Place your code here
The CLI Command will reset the Interrupt Enable Flag in the SREG Register.
At start of an Interupt routine this Flag will be cleared automaticly by hardware without any user command.
When the interrupt routine ends ( RETI Command in Assembler ) this Bit will be set by Hardware again.
So the command #asm ("CLI"); in an interrupt routine has no effect, because it will be set at the end of the interrupt routine again.
To get your program running declare a global bit variable in declaration section:
volatile bit ub_nointerrupt=0;
In your interrupt routine this bit will be set:
ub_nointerrupt=1;
And include the CLI command in the main routine - That will work
if(ub_nointerrupt>0){#asm("CLI");};
Thats not a Problem of CodeVision AVR, it appears at every Compiler Software, bacause it will be occoured by Hardware.
To lock an specific interrupt, it will be eaisier to reset the according interrupt enable bits.
When enable this bits again write a logical 1 to the according interrupt flag.
So the interrupt will not startet immediately at re- enabling the interrupt enable bit.
ub_nointerrupt=1;
thanks a lot for your help sir..
but the code is still not working properly..the interrupt is being enabled again and again..
i am using INT0 of atmega16 and it is falling egde triggered..
at the INT0 pin the input data is in the form of a bit stream comprising of 1 and 0..so while the subroutine is being executed if a falling edge is encountered at INT0 pin then the subroutine is being executed again..
i am writing my code below..please help..
int i;
ub_nointerrupt=1;
delay_ms(4.752);
for(i=0;i<11;i++)
PORTC=PIND&&0x04;
PORTA=0x00;
delay_us(864);
PORTA=0x01;
delay_us(864);
PORTA=0x00;
delay_us(864);
PORTA=0x02;
delay_us(864);
PORTA=0x00;
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTA=0x00;
DDRA=0xFF;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
GICR|=0x40;
MCUCR=0x02;
MCUCSR=0x00;
GIFR=0x40;
TIMSK=0x00;
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei");
while (1)
#if(ub_nointerrupt>0)
#asm("cli");
#endif
When the Interrupt follows are so short it would be able to disabler the int0 enable flag in the GICR register in the int0 interrupt routine:
GICR&=0b10111111;
So the Interrupt will be disabled and no furher trigger is allowed.
To avoid a false Trigger signal at re- enabling of the flag in the GICR Register.
Write a logical 1 to GIFR that will clear the according flag:
GIFR|=0b01000000;
GICR|=0b01000000;
Avisekdg
I have the same problem, is there a solution for that ?
I think that I not be able to disable other interrupts, I try a lot of thinks to disable, but no success.
Do you solve this problem ?
The solution if for most Interrupts the same.
Disable the according interrupt control register and write a logical 1 to the according flag register before re-enabling the interrupt.
The interrupt FLAG always been set when the interrupt condition is true.
But only when the inerrupt CONTROL Flag is active too, an interrupt appears.
The consequence is, first to delete the FLAG before enabling the interrupt, by the CONTROL bit an the assembler comand "SEI".
To clear an interrupt FLAG write a logical 1 to it.
Some interrupt FLAGS will be set, when the Function is enabled.
E.g. The USART
