earckens
Active Member
In the circuit attached (1st picture) I use succesfully a 74HC132 DIP package CMOS NAND Schmitt Trigger osillator (about 2.4kHz). I designed a pcb (at the rear of the 2nd picture showing both the protoype pcb and the production pcb) where the same IC is used in SOIC footprint. However I could not get the oscillator to function so I used a SOIC adapter board to use an SOIC in my protoype board (3d and 4th picture). Still the same, no oscillation: pin 4=H, pin 5 = pin 6 = H. I had ordered 2 batches of these SOIC's, so I tried one from Motorola, and only then would it work.
Conclusion: it seems as if SOIC's are more prone to batch failure.
Question: is that correct?
