diode help
banjomaniac
I'm attemting to repair a 4 in 1 rc helicopter controller and need to know if I can find a suitable replacement for a diode that smoked, it is available at Digikey part #SS24-E3/51TGI a 2 AMP 40V SMB. It doesn't have to be surface mount as I can solder a regular diode in it's place, I'm just wondering IF there is a replacement I might find to use, I don't think radio shack carries anything anymore other than resistors.
Thanks, banjomaniac
Thanks, banjomaniac
This should be equivalent.
FAIRCHILD SEMICONDUCTOR|S2A|BRIDGE RECTIFIER, 2A, 50V | Farnell UK
Do you know what 'Smoked' the diode in the first place?
If you don't and the fault hasn't been rectified, whatever the cause was will probably give a similar result....
