digital pid
hamm
hi i need to control postion of a motor using digital pid actually i m doing a project on plate mounted inverted pendulum mean a pendulum would be attached to the shaft of the servo motor through a plate or pulley.
i want help regarding digital pid assembly language algorithm and also i have a knowlege of analogue pid and pic18f assembly programming
You should make an attempt at writing it yourself. If you get stuck then post a specific question. Nobody is going to do your project for you, however, we will try to help if we can see that you have made a valid attempt.
