Just measure the voltage at the drain with a simple resistive divider. The voltage across the load is 20-Vdrain.
Can I ask, why you want to? The value will always be one of two values unless the load is capacitive or a motor. Assuming you want to know the current in the load, it would make more sense to put a low value resistor in the ground leg and measure the voltage across that.
