Diff. B/W CE,CB,CC?
What are the Differences B/W Common Emitter, Common Collector, Common Base? Exact Differences
" Can anyone Give the Diag. for All these in Different Biasing Methods like FIXED BIAS, EMITTER BIAS, VOLTAGE DIVIDER BIAS "?
And Explain them Briefly?
I Think i should have to get 3x3 = 9 Diagrams !
(Like., CE Configuration in FIXED BIAS, EMITTER BIAS, VOLTAGE DIVIDER BIAS and other Two)
A common base amp has low input impedance, high output impedance and voltage gain, but no power gain.
A common emitter amp has a relatively high input impedance, high output impedance, and can have both voltage and power gain.
Common emitter amps (also known as an emitter-follower) have a high input impedance and low output impedance. The voltage gain is slightly less than one (usually 0.9__), but it has current and power gain. It is used to buffer high impedance sources to low impedance loads.
Phew, what a good review of first semester.
crutschow
Most Helpful Member
You missed something in that first semester.
Perhaps you meant that a common-base amp does not have current gain but it can indeed have power gain. Since the input is low impedance and power = I²R, then the output power for a given current is greater than the input power if the output collector load has a higher resistance than the transistor input resistance.
mneary
You were probably thinking common collector, which is also known as emitter follower.
:eek:
Roff
All three configurations can have power gain.
