Device ID
jjegarcia
Using propic2 I found this error "No device ID found", but I the text area to introduce it is dissabled. Do you know what means Device ID? Do you know how to sort this out?
Each Pic Micro has a Device Id burned into it, so that a programer know that the chip it is programing is the right one.
Look at the Programing Specifications on the chip you are using. It tells about this Id number.
What chip are you using?
This could also mean that the programer cant find the chip??
Hardware Check???
Perhaps a few of the new PIC's might do this, but certainly the vast majority of PIC's don't - I've never seen one which does, but I only use the 16 and 12 series PIC's. It's certainly a feature I've wanted adding to PIC's, I would love to add automatic PIC detection to my WinPicProg software! - but there's never been any way to do it (until now, perhaps?).
I gess I was refering to the 18F series. I used PP18 that uses this feature. It only will let you program when it sees the chip that you choose.
When I do the 16F series, I use Fpp. It also don't check for a Device Id.
Sorry for my mixup
Got it Thanks
Yes, indeed its burned into the chip and once the software intends to program the uC read out the ID. I found problems in my PCB but its been sort it.......................Thanks
