Delay in Verilog Programme
abdulbasit
This coding is for a sorter whose arm moves in two directions. Now what i need is to put in delay after the detection of bar code from the bin. During testing of this code, by the time Bin reaches the arm its already back to its initial position. So a delay for 5seconds is required in the coding after detection.
module trial(clk, a, b, RCServo_pulse);
input clk;
input a, b;
output RCServo_pulse;
reg [7:0] RxD_data_reg;
always @(posedge clk)
begin
if ((~a) & (~b)) begin
RxD_data_reg <= 8'b00000000;
end
else
if (((~a) & b) | (a & (~b))) begin
RxD_data_reg <= 8'b11111100;
end
else
if (a & b)
#10000 begin
RxD_data_reg <= 8'b10000000;
end
end
parameter ClkDiv = 195; // 50000000/1000/256 = 195.31
reg [7:0] ClkCount;
reg ClkTick;
always @(posedge clk) ClkTick <= (ClkCount==ClkDiv);
always @(posedge clk) if(ClkTick) ClkCount <= 0; else ClkCount <= ClkCount + 1; /* reset ClkCount when 1 tick
else continue counting*/
reg [11:0] PulseCount;
always @(posedge clk) if(ClkTick) PulseCount <= PulseCount + 1; // for each tick increment pulsecount 1
// make sure the RCServo_position is stable while the pulse is generated
reg [7:0] RCServo_position;
always @(posedge clk) if(PulseCount==0) RCServo_position <= RxD_data_reg; /*first time through Pulsecount output width of pulse
thereafter output 0 until time for next pulse*/
reg RCServo_pulse;
RCServo_pulse <= (PulseCount < {4'b0001, RCServo_position});
endmodule
