panic mode said:Try replacing potentiometer for bigger one, it sounds like you have 1kOhm only. Use 5kOhm.
crust said:Post your circuit -- but you might not have the right values for your resistor and potentiometer.
The equation is V=1.25(1 + R2/R1)
R2 goes from the adjust pin to ground and R1 goes from adjust to the output. R2 should be about 200R1 or thereabouts.
