What voltage do you have to start with? We know you want 12 volts out, but we don't know what voltage the input to the regulator is.
The datasheets for the LM317, LM338 and LM350 regulators show that they reduce their maximum output current when the voltage from input to output exceeds a fairly low voltage. For the LM317 if the input is 27V and the output is shorted with a cold filament the current is limited to typically 1A but it might be as low as 375mA which will not light the bulb.i am using 2 lead acid battries in series. so a max of 27v down to a minimum of 20v may be there at the input of the regulator or transistor.
I used two 7812's in parallel and also used lm338, 5A regulator. since load is very high 1.2ohm that cause an initial current of 10 to 15 amps and shuts the regulators off.
Ok - so you're dropping 27 volts to 12v and powering a 21 watt lamp.
Thats 1.75 amps and a 14 volt drop so you'll be dissipating around 24 watts of energy - unless you have a large heatsink on your regulator, it's going to get very hot very quickly.
He said he tried an LM338 right.
Qaisar:
Why dont you do a test on the bulb. Run it at 1v, write down the current it draws. Run it at 2v, write down the current it draws. Run it at 3v, write down the current it draws. Do this up to 12v, writing down the current for each voltage level.
This way we will know at a glance what is going on. We can only guess unless we have the bulb data.
Also, what kind of heat sink are you using on the LM338?
another question rises here is why a 100w tansisor can't wighstand with only 21w bulb???? the power dessipated in the transistor is P= (27V-8.6V)*1.5A = 27.6W in the transistor which is too less than 100W..... then why it blown out??????? i used a normal small finned heatsink...
its a good idea MrAl; i must test is tomarow. i wrote about My experiment with LM338T in post # 28.
My old Weir linear supplies will give me up to 5 amps and go into current limit as soon as I hook up a high wattage 12v bulb. With a large capacitor in parallel with the output they will happily run the bulb - it's just overcoming the current limit with the cold filament.
The same happens with large motors with a high start current but minimal running current - without a large cap on the PSU or "jump starting" them with a 12v SLA they won't run.
MrAL said:...One answer is that the bulb heating curve does not allow the bulb to heat up enough with the current limited current level, and so the resistance can never increase even though the LM317 (or similar) does not have fold back current limiting. ...
MrAL said:... One thing about those car headlamps is that they have a pretty big filament (high mass more or less). But that would imply that the regulator could never put out enough current to heat the bulb, ever, ...
Thermal conduction losses are relatively small, it's the black body radiation from the filament that dissipates most of the power. And that doesn't become very significant until the filament starts to glow a dull red.............................................
It's also a little difficult to judge the thermal characteristics and keep in mind that the bulb, when hot, can easily dissipate 24 watts of heat. If the bulb was completely covered in insulation (which might make for another test) only then would we have the situation you are talking about. And remember that if there were no thermal losses the bulb would heat up to an infinitely high temperature (assuming it could survive).
So make no mistake, the thermal losses are truly part of the model and can not be ignored.
What is the heat rise per watt of that heatsink ? If it's something like 12 degrees / watt then putting 27.6 watts of heat is going to raise the temperature to 324 degrees C
