Dc Motor...!
Greatbuddy
Hello everyone,
Actually i need a DC motor which must satisfy the following requirements :
1) RPM - 600 - 1000
2) Power supply - 3-5v
3) Dimensions - Must be small in mm
Let me know if further required..
Have you tried googling for the motor? A 5V DC motor in the RPM range you require (I think most run at about the same speed.) are very common. You shouldn't have any trouble finding it.
I think a 5v DC motor with around 1000 rpm should satisfy your requirements.. Measure the current rpm with an rpm counter.
RPM pick-up device is already done by Kadett200is! Check out the adjacent thread.
[EDITED: WARNING GIVEN FOR BAD LANGUAGE]...
The RPM of a DC motor depends on its load. It might spin at 18000 RPM without a load.
A vibrating dildo spins much slower.
Ha is there any motor which domp my requirements,
If yes then provide me a datasheet for that motor plssssssssssss,
Iam badly in need of that and want to buy it ASAP.
Thanks to all.
Most of us are not in your country so if we specify a motor then you won't be able to buy it. You should ask for a motor made in India on an Indian website.
Look at robot sites for motors. You'll probably need one with a gearbox to get a low RPM like 600 or so. This site has some motors, but they don't meet your exact requirements:
Hi Greatbuddy take this advise form audioguru
to buy something quick look localy
Plssssssssss = if the motor is hot and you drop it into water :confused:
Robert-Jan
Hello everyone,
1) RPM - 600 - 1000
You haven't provided enough information.
Torque?
You could get a 5V 1000rpm motor but it'd be useless if it isn't powerful enough.
You say "small in mm" which means nothing, is that 1mm or 100mm?
