DC-DC converter
PratapKollu
Hai
I need a DC -DC converter
input is from USB , 5V
Output required , +12 V , GND, -12 V
Does such DC-DC converter exist?
Thank you
Pratap
RMMM
linear tech has a few.. It really depends on your current requirement.. but check out
linear.com
ericgibbs
Most Helpful Member
Reloadron
Most Helpful Member
You don't mention your current requirements? However, since you mention USB you need to keep in mind that if this 5 volt USB source is from a home PC the ports are limited in the 5 volt current they can provide. You really don't want to overload or accidently short a USB ports 5 volt power. Also, if this is a low current +12 / -12 volt application and you are using a home computer, there should be + / - 12 volts available from the power supply.
Ron
