Data Sheet for UC3825N & CD40013PC?
Appleon
Anyone have the above mentioned 2 data sheets? The UC3825N is a PWM IC chip while the CD40013PC seems to be a NOR chip.
Thanks!!
Cheers!!
Appleon
CD40013 - i think - no existiert. CD4013 is a dual D flip-flop.
I have both datasheets, e-mail me.
datasheets
are you sure it isn't the 4001 you're after? 14-pin package? That's a quad NOR gate.
A quick web search turns up both datasheets;
(It helps to know that motorola's 4000 series parts have a MC14xxxx prefix rather than CD4xxxx)
Thank you!!
Hey thanks guys, found the datasheets necessary!! By the way, how exactly did you all find the data sheets? I tried various search engines but could not locate any source at all...
Thanks again!!
Cheers!!
Appleon
finding datasheets online
Unfortunately, not all of the chip vendor info shows up during web searches. I usually try "part # + datasheet" then just "part #" with some likely combinations of prefixes and suffixes. I've come across some schematics and datasheets where the text is in a foreign language, and Googles' translate feature can help with that.
part of it is just knowing where to look. For example, since TI bought out Unitrode some years back, that's where I looked for the switching regulator. And knowing that Mot. used a different prefix for their 4000 series parts helped. If none of that works, this board is a good resource.
- CAL
