jakeselectronics
Hey Everyone.
I want to make a simple Current Meter that measures up to 1A and I want to display this on 10 LED Bar Graph Array. (10 LED's in a line in the 1 package)
So, 0-99mA will light 1 LED. 100-199mA will light 2 LED's and so on.
I was thinking of using the LM3914 to drive the LED's, but this means I need to convert the Current to a Voltage.
So, I was thinking of using this part; ASC712 Hall Effect Current Sensor
I think you can put it in series with the circuit and the IC picks up the magnetic field and outputs a voltage.
185mV per Amp for the 5A version.
So becasue I want to measure up to 1A in increments of 100mA, I need the LM3914 to measure a Range of only 0V - 185mV (18.5mV increments)
I cant understand the LM3914 datasheet on how to adjust its range.
Can anyone help?
Or is there a better way to do want i want to do?
Can anyone help?
