The user selects the level of current from an interface in the computer. Then the computer communicates wit a circuit and that specified current is injected from the circuit into a relay. The tripping time is sent back to the computer.
Super_voip said:A careful selection of currents via the relays will reduce the amount of relays needed eg 1,2,4,5 Amps will give you 0-12Amps in 1 Amp steps except 8amps.
Super_voip said:Doesn't matter, circuit breakers will work with either, as for the current try relays switching at, say, 1 Amp levels and transistor-fet to supply at lower levels. So have a bank of relays directing the voltage source through a resistor which will keep the current to desired level to a paralleled output.
Jester009 said:I have to inject an AC current ranging from 0-5A. Triacs or Thyrisotors do not produce pure sinusoidal waveforms. do they?
