mactack said:Hello,
I'm looking for a crystal oscillator (I'm building a digital clock). Would this one do: **broken link removed**
What capacitors should I use, 36pF ?
I believe what you want it Load Capacitance, which is given on your data sheet as 18pFWhat capacitors should I use, 36pF ?
BeeBop said:Hi,
The oscillator contains an amplifier/transistor. The crystal provides a feedback path to make the amplifier/transistor scream at a set frequency.What is the difference between a crystal and an oscillator? The oscillator includes the capacitors?
I only made that suggestion because 18pF looks close to what has always worked for me. On any pic I have had good luck with 15 or 20 pF caps, and I never go through all the calculations, etc, which you find in the PIC data sheets. 36pF seemed a little high, but it will probably work too.Ah, I thought I had read somewhere it should be a little under twice the load capacitance...
