Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Thanks for the input. After a hour of searching on the net, I come to the conclusion that they are probably just plain crystals.
The reasons is that all surface mounted crystal oscillators I found so far have connections along the length of the module instead of at the ends.
At least two sources suggested that the reason for two connections at each end in the above image is because customers can order the package with internal crystal connections at both ends or at one end to suit their circuit design.
Crystals are available in these packages too, in wich case eighter the pins are connected to each other 2by2 internally or eighter 2 pins are not connected.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
