CRT Oscilloscope - controlling deflector coil with MOSFET
sleeper1987
Hi.
I'm trying to control an old CRT using a microcontroller, and I need to drive the deflector coils with reasonably large voltages.
I've got a few questions I'd really appreciate some help with:
- To deflect the beam both ways, I need to be able to apply a positive and negative voltages to the coil. Simplest way, I figure, is to bias one side at a mid voltage, and swing the other beween 0 and the maximum. Does this sound reasonable?
- I'm not sure how to switch the larger voltage using the microprocessor's 5v output. I could use PWM to control a mosfet in saturation, or get an analogue voltage via a resistor ladder, to operate it in linear mode. How would I go about doing either of these, and as I understand I need Vgs to be greater than Vds in either case?
- The coil has a resistance of something like 60ohms. How should I isolate it from the power supply, so as to prevent it effectively shorting the supply when connected by the mosfet?
Any help would be greatly appreciated!
How about an H-Bridge?
Deflection amplifiers are usually a voltage-controlled current source.
Thanks for the replies!
As for the audio power amp: How can I tell if it's capable of handling inductive loads? Would any amp designed to drive speakers directly be ok for that?
Unfortunately, I'm restricted to buying from here, so there's little choice:
Do any of those seem suitable?
Thanks again.
Typically the vertical coils require little current and are slow to respond. They are built to run at 60hz. The horizontal coils take much more current and run faster. TV=15khz. VGA=32khz. The coils deflect the beam with current so the amplifier must have current feedback.
Is the CRT from a TV or monitor?
Interesting! In that case, I'll probably rotate the coils so that the horizontal one is slower. The CRT's from a TV.
