creating signal using pic 16f690
hobby_85
Hey, Im trying to build this project of mine where I need to send a signal (ANY kind of signal) using a PIC at certain intervals. But for testing purposes, Id like a signal sent every few seconds. These signals are generated in the PIC and transmitted through a ultrasonic transmitter.
Now, as long as the ultrasonic receiver can detect the signal coming in, I have no qualms about the type of signal being sent.
What would be the easiest way to go about writing code for this? I'm using a PIC 16f690, running at Vcc=5v, and my code is in C.
Im also adding a voltage multiplier at the output of the PIC before the US transmitter so I could amplify the signal before it goes out.
Im still doing my tutorials in how to program a PIC (reached the comparator stage so i know how to detect the incoming signal!), so not sure on which part I have to look at for sending waves/signals.
Thanks!
hey all, ive been looking around the internet to try and create a signal using the pic 16f690. Read alot of stuff on PWM and all that. Then I came across this one code written by 3v0 on this very same forum. Makes heaps of sense and seems easy to implement. heres the code:
int i;
int percent;
percent = 52; // % time on
while(1) // loop forever
for (i=0; i>100; i++)
if (i < percent)
ra0 = 1; // turn bit on
else
ra0 = 0; // turn bit off
delay_ms(1); //some sort of delay here, determines freq
-------------------- OR --------------------------
if (i == percent)
delay_ms(1); // some sort of delay here, determines freq
and heres the site i found it on:
https://www.electro-tech-online.com/threads/pic-pwm-outputs.34096/
So basically, the code switches the output to high or low, depending on the duty cycle. My question is if i were to connect this to a ultrasonic transmitter, would it work? would it be sending a rectangular wave? If so, how do I adjust it such that the wave is 40khz.
so why do people use pwm instead of this switching method above, given it seems easier? Sorry if my question seems rather easy, im still new to MC;s.
thanks in advance.
