Hello all,
I am hoping that a correct relay will be able to help me with my project. I have tried 2 different relays and I can not get it to work... Also, I need to use the smallest possible 12 V DC relay. I have used Omron's G5A- relays.
Here is the scenario that I am trying to get working.
1) I need a relay that will take +- one time and the next time the signal will be -+. Polarity changes with each momentary signal.
2) I have 2 12V diodes, D1 and D2 that will be controlled by the relay. Once the relay is engaged it will turn on D1. The next time relay is engaged it will turn on D2 and turn off D1. The next time it is engaged it will turn on D1 and turn off D2. And so on...
Thanks you all for your help... Not even sure if this is possible.
Regards,
Renato
Regards,
Renato
