Copper pour "Blobs", what to do with them ?
ItsMike
Hey everyone,
I'm designing a pcb in eagle and I made a copper pour on the bottom layer.
Since I used a rather high isolation (etching at home) I got those copper blobs which do not connect to anything between components/pads ect... (See attachment).
Do I need to get rid of them ? do they have any effect on the circuit ? (parasitic capacitance/noise whatever).
What would be the easiest way of getting rid of them ? I could do that in photoshop since I use it to invert the colors anyways.
Thanks in advance, Mike.
The isolated blobs are not normally a problem, expect perhaps in RF type circuits. So you can leave them there if you like.
if you want the blobs to be connected to circuit ground use a trace width of 0.254mm (0.01") and draw a wire from the ground pour into the area you want to fill with a non isolated ground fill.
Name the short piece of wire "ground" (GND) and perform "ratsnest". Ratsnest then connects the blob to circuit ground.
Please refer to the attached five screenshots.
Note the highlighted area. It's all connected to ground. Also note the difference between image4 and 5. Just rerouting of one cap improved the overall ground pour to almost 100%.
Boncuk
The "blobs" are also called "orphans" in Eagle. When you make your polygon, you have the choice of orphans on or off. Try that switch. If you already have the polygon, go to information ("i"), click on the copper filed area, and be sure the orphans box is not checked.
John
Thanks a lot.
So it's just aesthetics ? I might as well just turn those "orphans" off without any impact on the circuit, right ?
Also, I've noticed there is a similar option for the polygon - "Thermals" - What does that do ?
"Thermals" connect pads to a copper pour by thin connections, i.e., 4 bars between the pad and the copper pour, if the pour completely surrounds the pad. It is done to facilitate soldering. Soldering to a pad in the middle of a copper pour without thermals is more difficult. You cannot turn thermals on or off for specific pads, but there are various workarounds.
John
Thanks a lot.
sometimes it might have impact on a circuit, especially working with operational amplifiers at high frequencies. Semiconductor manufacturers recommend signal traces on one layer and a full ground pour on the other one.
Even working with less sensitive circuits using a good ground pour shortens etching time and takes care of equal etching (no under etching of thin traces while etching a big area.)
Last not least etching as little as possible saves etchant and helps to keep a cleaner environment.
