converting from Swordfish to Assembly
MrDEB
I have a PWM circuit and code for a 18F1320 BUT a smaller PIC would be more cost effective.
How does one convert from swordfish to assembly or ?? using a smaller cheaper PIC.
need 3 PWM outputs.
Which PIC do you plan to use, none of the smaller than 8pin devices have hardware PWM. If you're planning to use a 12F series and the PWM is slow enough you could do 3 channel in software.
Anything smaller and cheaper than an 18 pin PIC
right now I am using an 18F1320.
See my link to Neckerchief on fire for finale result of project prototype.
will post code in few miniutes need to locate.
swordfish code I am using
it works very well for a flickering flame effect.
changing the randomval creates different effects.
Device = 18F1320
Clock = 8
//Include "IntOSC8.bas"
Include "RandGen.bas"
Include "Utils.bas"
//Include "ADC.bas"                   // Include the ADC.bas library
 #option AD_RESIST = 800000 //11XXXXXXXX
 Include "InternalOscillator.bas" //22XXXXXXXXX
 Include "ADC.bas"        //33XXXXXX
 Include "MinADtime.bas"  //44XXXXXXXX
//Dim LED As PORTB.3                  // Declare the LED pin turns on transistor
Dim LED0 As PORTB.0, LED1 As PORTB.1, LED2 As PORTB.2, LED3 As PORTB.3//55XXX
//OSCCON = %01110110                 // Setup the internal OSC for 8Mhz
Dim TMR2IE As PIE1.1,         // TMR2 interrupt enable
    TMR2IF As PIR1.1,         // TMR2 overflow flag
    TMR2ON As T2CON.2,        // Enables TMR2 to begin incrementing
    Signal_Pin As PORTA.3     // Signal output to frequency meter
Dim Red_Pin As PORTB.0,
    Green_Pin As PORTB.1,
    Blue_Pin As PORTB.2,
    Red_Duty As Byte,
    Green_Duty As Byte,
    Blue_Duty As Byte,
    Red_DutyVal As Byte,
    Green_DutyVal As Byte,
    Blue_DutyVal As Byte,
    RandomVal As Byte
Dim uS As Word,
    mS As Word
 Const DarkVal = 512 //XXX
 Function Get_ADC_Sample() As Word       //2xx Function to grab the ADC sample
   Result = ADC.Read(0)                 //3xx Grab an ADC sample from channel 0
 End Function                            //4xxxx
 //ADCON1.0 = 0                            //5xxx Configure AN0 as analogue
Interrupt TMR2_Interrupt()
    High(Signal_Pin)
    Save(0)                   // Back up system variables
    If TMR2IF = 1 Then        // Check if the interrupt was from TMR2
        TMR2IF = 0            // Clear the TMR2 interrupt flag
        uS = uS + 50
        If uS >= 1000 Then
            uS = uS - 1000
            Inc(mS)
        EndIf
        Inc(Red_DutyVal)
        Inc(Green_DutyVal)
        Inc(Blue_DutyVal)
        If Red_DutyVal > Red_Duty Or Red_Duty = 0 Then
            Red_Pin = 0
        Else
            Red_Pin = 1
        EndIf
        If Green_DutyVal > Green_Duty Or Green_Duty = 0 Then
            Green_Pin = 0
        Else
            Green_Pin = 1
        EndIf
        If Blue_DutyVal > Blue_Duty Or Blue_Duty = 0 Then
            Blue_Pin = 0
        Else
            Blue_Pin = 1
        EndIf
    EndIf                     //
    Restore                   // Restore system variables
    Low(Signal_Pin)
End Interrupt
Private Sub TMR2_Initialize()
    TMR2ON = 0                // Disable TMR2
    TMR2IE = 0                // Turn off TMR2 interrupts
    PR2 = 149                 // TMR2 Period register PR2
    T2CON = %00000001         // T2CON 0:1 = Prescale
    TMR2 = 0                  // Reset TMR2 Value
    TMR2IE = 1                // Enable TMR2 interrupts
    TMR2ON = 1                // Enable TMR2 to increment
    Enable(TMR2_Interrupt)
End Sub
// Start Of Program...
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 30
Green_Duty = 0
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 0
Blue_DutyVal =0
uS = 0
mS = 0
 //Function Get_ADC_Sample() As Word       //2xx Function to grab the ADC sample
 //  Result = ADC.Read(0)                 //3xx Grab an ADC sample from channel 0
 //End Function                            //4xxxx
RandGen.Initialize(128)       // Initialize the Random Number generator
TMR2_Initialize               // Setup and enable TMR2
While True                    // Create an infinite loop
 If Get_ADC_Sample > DarkVal Then     //7xxx Monitor for change
    RandomVal = RandGen.Rand  // Grab a random number from 0 to 255
             Red_Duty =RandomVal-25
            If Red_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Red_Duty)
            EndIf
             Green_Duty =RandomVal-20
            If Green_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Green_Duty)
            EndIf
             Blue_Duty = RandomVal-30
            If Blue_Duty > 0
              Then  mS = 0
                Repeat
                Until mS = 19
                Dec(Blue_Duty)
            EndIf
              Else                                //8xxx
        Low(LED0)
        Low(LED1)
        Low(LED2)
        Low(LED3)
    EndIf    //9xxxxxx
Wend         //10xxxxxx
         End
You could convert it to the free BoostBasic and compile it for a 16F628A ($1.70). However the 18F1320 is only $2.90 - is it worth the $1.20 saving?
need 3 PWM outputs.
If you look in the folder where the swordfish basic resides, after you have compiled the basic file, you will find the assembler listing.
I found an 8 pin circuit w/ code on INSTRUCTABLES late last night BUT the file is a RAR which I can't open. I can't even find the artical again but have the download.
The 1320 @ Mouser is $3.24 in an ssop package. Its smaller than the 18 pin dip. The SMD resistors are .50+ per. If to much trouble (seen some of the other candle simulations, pretty lame) then maybe just stick with the 18F1320 in the ssop package and surface mount some 1/8 watt resistors etc. Entire unit gets epoxy covered anyway.
Besides the unit I built has 3 LEDs, 2 yellow and one red.
I have a board kinda designed for the surface mounted resistors etc using the 1320.
Kinda sounds like I am bailing on using a smaller PIC but I like the effect better.
hi D,
Download the free unzip: its unzips almost everything, so watch out for your flies.!:rolleyes:
Thanks Eric for the download
Looked at file and it is pretty lame.
Only one LED
Will relook at the SMD resistors. I guess I looked at the wrong ones.
Is a total rewrite worth the trouble?
I wish I knew more about code writing. Just getting comfortable with Swordfish.
The 16F505 looks promising BUT a total rewrite is involved.
gonna have to think about this.
Tonight I am wearing my protype to awards dinner. LOTS of scout leaders will be present.
At present , using an SSOP pkg PIC and SMD passive componets plus a circuit board = $6 more or less.
add 30% profit margin plus 10% for shipping costs to get parts in my hands.about $10 per unit.
If you think there's any chance at all that you might be doin' things with the 8 or 14 pin devices with a 14-bit core then you owe it to yourself to start learning one of the C languages.
Swordfish BASIC is by far the best BASIC language I've come across but (1) it limits you to 18F' devices, and (2) it's BASIC. I don't have anything against BASIC but unfortunately it's not considered "mainstream".
You shouldn't have too much trouble converting BASIC program statements into C statements though there will be a learning curve. Why not download the free/lite versions of BoostC and check it out?
Kind regards, Mike
You shouldn't have too much trouble converting BASIC program statements into C statements though there will be a learning curve. Why not download the free/lite version of BoostC and check it out?
Kind regards, Mike
Kind regards, Mike
Wholeheartedly agree.
Will give it a go as I have my second computer working. Still need to figure out how to use MPLAB and get the Junebug configured better. Right now I need to COMPILE, PROGRAM 2 times before the hex file shows up to use Junebug to program the PIC. It works but not smoothly.
